Hi all, cut a long story short, bought COD Ghost, installed, had errors, gfx card didn't meet spec, can't play the game.
Problem: Need a Gfx card that will run Dx11 and will work on my below (in the sig) spec.
I OC'd the Q6600 to 3.0Ghz so will meet minimum requirement for CPU.
I plan to upgrade my system in March once I get my bonus so didn't want to spend too much now as I may go from Intel back to AMD due to cost and spec.
So a good'ish Nvidia PCI-e 1-2Gb card under £150 would be appreciated.
Thnx in advance.
Thnx in advance.
