cheapish mobo
17 Dec 2007
Easington Lane
Good morning all. Its pay day and i fancy a new mobo. I currently have a q6600 running at 2.88Ghz but fancy more. It needs atleast 4 sata and 5.1 audio on it. Im using 2x2gb ram ddr2 800 and a 8800gt 512mb gpu. It also needs to be pretty easy to overclock aswell please.
could you give me any examples and what speeds i could get out of my Q6600? dont really want to spend more that £60
sorry about the late reply decided to get a new case before my motherboard (p182). Currently i have a asus p5kpl-vm. I have got my Q6600 up to 2.88Ghz just by using a overclocking profile in the bios but i can not see where i could get it any higher. Still not too sure what i want next. Any ideas?
im using one of them artic freezer pro's. On the motherboard i have at the mo there is overclocking profiles which will overclock it by a percentage. I have it at 20% at the mo but if i try 30% it wont boot up. Which motherboard do you recommend?
apart from the profiles will the BIOS on your existing mobo let you set things like CPU:RAM ratio & CPU/RAM/chipset voltages manually?
