Good evening!
I've just attempted to fit an SSD into my girlfriends PC which is refusing to detect it
so I am tempted to replace it with something super cheap but with some reasonable power. After a bit of a look around Google the current gen of Celerons seem to offer good power while being extremely cheap.
Current spec is: E6550 2.33 Core 2, 6GB DDR2-800, Intel DG33FB.
I don't need disks, graphics card or PSU as these can be removed from the existing build. On a competitors site I can get a G550, motherboard and 8GB DDR3 for just a smidge over £100.
What would you guys recommend? It is used for web browsing, bit of Office work and the odd hour of Sims 3.
Thanks in advance, you guys are awesome
