Cheapy graphics card upgrade.
25 Dec 2008
Birmingham
I've a Ryzen 8600G with an RX 580 (not 2048SP) but XXX GTS black edition. I've a budget of £150 which is small for this upgrade I guess.
I've the option of a 5600 XT, 1070Ti or a 1080 (Gigabyte Xtreme gaming edition).
Which out of those 3 would anyone recommedn or is there something else I should be buying. I sold my ARC A580 as I couldn't live with the
bad drivers and performance in older games.
450W Bequiet PSU, 32GB ram. 1080p gaming; nothing higher.
I expect over the coming weeks you could get a new 6600 for that, which performs similar to the three cards you mentioned and has the lowest power consumption of ~130 watts.
Of the three, the 1080 is the best performer, though I think the model you quoted uses 2x 8 pins.
Yes my ARC card used 2x 8pin connections. 1080 is GDDR5 pcie3 and the 5600 xt Gddr6 and pcie4. So I wasn't sure.
Thanks
Surely you can get a 1080ti for £150 in fact you defo can and I would recommend that.
Is 6650XT a bit better than 6600?
Yes
