Cheat Alice Madness Retuns.
EJB
EJB
28 Dec 2010
I am unable to get past a boss fight.
I can edit the code to allow Godmode...but...it won't save saying 'Access Denied'
Played the game through when it came out but not able to do it now!
Any help Please?
Yes!
I have since gone back to the beginning of the game but would like to get past it next time!!!
PS. AHarvey don't quite understand that?...I guess I have to change the code for that also....which I can't do???
that depends how you are cheating, if you are using a built in cheat code then the game will know you've cheated and cause issues.
Cheat Engine allows you to choose select memory blocks associated with a game and to edit them or freeze them. It would be a case of finding the correct section for health and freezing it. Or seeing if there is a cheat engine table available to download for the game.
I am cheating (trying) by going to the relevant file and changing the value for damage from a figure to zero (0.0).
The file opens in notepad but when I try to save it says 'access denied'
I have noticed...when searching...that there are downloads for cheats but have never considered that as it is probably over my head and I am wary of causing problems!
