Check comment on this case for me
18 Aug 2006
ChCh, NZ
I' interested in a deal elsewhere. It would be the http://www.overclockers.co.uk/showproduct.php?prodid=CA-175-CM&groupid=701&catid=7&subcat=29
along with the http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-CM&groupid=701&catid=123&subcat=1103
for £129 excluding P&P.
My question is really on the case. Would it fit the latest offerings from ATI and their incredible size. I would only be buying the 5850 and XF it at a later stage. So no 5870's or 5970's. Would it fit comfortably? I also might throw water cooling in at a later stage and don't want too little space.
Your set up would fit in there no problem, but it is a decent AIR cooling case, if you are thinking about water cooling in the future (especially x fire!!) you will need room for a QUAD rad (or 2 120.2s) and you will not fit them in the scout.
