- 22 Nov 2009
- Cornwall
Going to buy a new build next week and most likely going to do a build log so you peeps can follow that if you like.
In the mean time could you check over this and let me know if I'm missing anything or suggest anything.
I already Have a:
Corsair Air 540 + eLoop fans
Aquacomputer aqualis XT nano coating (Getting off other site cus its cheaper)
Aquacomputer D5 pump USB aquabus interface (Same as above)
Aquacomputer aquaero 5 LT (Same as above)
YOUR BASKET
1 x Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red £499.99
1 x Intel 5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75930K) £439.99
1 x Samsung 1TB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE1T0BW) £324.98
1 x Gigabyte X99 SOC Force Intel X99 (Socket 2011) DDR4 EATX Motherboard £299.99
2 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £289.99 (£579.98)
1 x Avexir Platinum 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AVD4U24001604G-4M) £199.99
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White £149.99
1 x Samsung 256GB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE256BW) £144.95
1 x EK Water Blocks EK-Supremacy EVO Elite Edition - Intel 2011 £84.95
1 x XSPC RX360 Triple Fan Radiator V3 £84.95
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x XSPC RX240 Dual Fan Radiator V3 £64.99
1 x NZXT HUE RGB LED Controller - Black £39.98
1 x Cooler Master Seidon 120V, AIO Cooling Solution £39.95
1 x EK Water Blocks EK-D5 X-TOP CSQ - Acetal £25.99
1 x Mayhems Blitz Pro Cleaning System £24.95
2 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - Orange £24.95 (£49.90)
1 x BitFenix Alchemy Cable Bundle - Orange £21.95
1 x Mayhems X1 Clear Coolant 5ltr £21.95
1 x Gelid Solutions GC-3 10g Extreme Performance Thermal Compound £19.99
1 x Bitspower Mini-Valve - Matt Black £16.98
1 x Bitspower Fitting 1/4 inch ID to 13mm plugs - Deluxe White £9.95
4 x Bitspower angle 1/4 inch to female 1/4 inch - Deluxe White £7.99 (£31.96)
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Orange £6.98
2 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Red/UV Orange £6.98 (£13.96)
1 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, White £6.98
1 x ModMyMachine Shoggy Sandwich V2 for your Watercooling Pump £6.98
1 x XSPC Hose Cutter (0-25mm) £6.95
4 x Bitspower adapter 2x 1/4 inches - Deluxe White £6.49 (£25.96)
4 x Bitspower adapter 2x 1/4 inch - long Deluxe White £6.49 (£25.96)
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Orange £6.49
8 x Bitspower multi adapter female 1/4 inch - Deluxe White £5.99 (£47.92)
2 x BitFenix Alchemy 3-Pin to 3x 3-Pin Adapter 60cm - sleeved orange/black £5.99 (£11.98)
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Orange £5.99 (£11.98)
2 x BitFenix Alchemy Molex to SATA Adapter 45 cm - sleeved orange/black £5.98 (£11.96)
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved orange/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Orange £4.49
1 x BitFenix Alchemy 2pin I/O extension 30cm - Orange £3.95
3 x Akasa AK-TK-02 Cable Tidy Kit £2.99 (£8.97)
1 x E22 Clear 24 Slot Cable Comb (Small) 3mm £1.55
2 x E22 Clear 14 Slot Cable Comb (Small) 3mm £0.90 (£1.80)
6 x E22 Clear 8 Slot Cable Comb (Small) 3mm £0.80 (£4.80)
8 x E22 Clear 6 Slot Cable Comb (Small) 3mm £0.67 (£5.36)
4 x E22 Clear 4 Slot Cable Comb (Small) 3mm £0.60 (£2.40)
Total : £3,478.73 (includes shipping : ).
I already Have a:
YOUR BASKET
If i wasnt fussed about the 5930k then i would most likely i would go for s 4790k and save a fair amount of £££.
