Hello. I've made a couple of changes to my spec and I was just wondering if you could check it over for me..? With regards to my PSU, will 450W be enough to handle this rig?
And if you think anything else should be changed... My budget is 1000.
Thanks in advance for your help!
Kind regards,
-Alex.
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£59.95 £59.95
HD-087-WD Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM (HD-087-WD)
£98.95 £98.95
MO-019-OK OcUK Value Hanns-G HC194D 19" LCD Monitor - Silver/Black (MO-019-OK)
£104.99 £104.99
KB-054-MS Microsoft Comfort Curve 2000 Keyboard (KB-054-MS)
£11.99 £11.99
KB-026-MS Microsoft Basic Optical Mouse - Retail (KB-026-MS)
£9.99 £9.99
MB-011-IN Intel DP965LT 965 (Socket 775) PCI-Express DDR2 Motherboard - Retail (MB-011-IN)
£69.99 £69.99
CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£116.99 £116.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£119.99 £119.99
CD-035-NE NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-035-NE)
£19.95 £19.95
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£66.99 £66.99
OS-001-MS Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01528) (OS-001-MS)
£52.99 £52.99
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£125.99 £125.99
Subtotal £837.80
VAT £146.62
Total £984.42
Kind regards,
-Alex.
£59.95 £59.95
£98.95 £98.95
£104.99 £104.99
£11.99 £11.99
£9.99 £9.99
£69.99 £69.99
£116.99 £116.99
£119.99 £119.99
£19.95 £19.95
£66.99 £66.99
£52.99 £52.99
£125.99 £125.99
Subtotal £837.80
VAT £146.62
Total £984.42
