Check My £1500 Spec Plz
The DVD drive has nowhere to go as the case has no external bays, you can install from a USB drive.
The PSU isnt the best, a good 550W PSU would be plenty for a single GFX card, EVGA GS/G2 or Superflower Leadex are better choices.
CPU+board bundle - https://www.overclockers.co.uk/giga...-6600k-bundle-20-pounds-saving-bu-021-gi.html
You need a heatsink, the cpu doesn't come with one.
Just noticed the price of the asus GTX970 has gone up, this one is a better value - https://www.overclockers.co.uk/giga...graphics-card-gv-n970wf3oc-4gd-gx-149-gi.html
I'd probably go with two 250GB 850''s and a mechanical drive of your choice.
I'd recommend you swapping out the PSU for EVGA, gold certified 10yr warranty. 550w or 650 max. 750 is a little bit overkill.
Have you seen NZXT s340? Excellent cable management for clean look. A little bit smaller and also cheaper.
Lovely to build.
If your money allows it, mechanical is definitely what you want
250Gb should be ok and workable.
I guess you wont have all games installed at once and only a few of the bigger titles.
