- 7 Aug 2004
Hey all, had a swiftech kit before, was good, not amazing compared to my T Tower, however im thinking of a W/C kit that will knock socks off, which I can use on my dual core opty now and also for my quad core 775 when I get it, so after a little research iv come up with:
D-TEK FuZion CPU Block
Barb - Size: 1/2"
HWLabs Black Ice Stealth GT360 (Black) x 2
Barb - Size: 1/2"
Laing D5 Vario pump
Cape Coolplex 25cm Black Reservoir
Barb - Size: 1/2"
Danger Den 1/2" ClearFlex 60 Tubing (15 feet worth)
Zinc Plated Jubilee/Wormdrive Clip 12mm to 20mm (12)
6 x 120mm 14db fans
Zerex Super Coolant 50ml
What do you think ? its got 2x 120.3 mm rads, and im thinking of installing with flow starting with pump:
pump --> cpu block --> rad 1 --> rad 2 --> res --> pump again etc
Or could have the above setup but go rad 1 --> res --> rad 2 --> (so water 'sits' as long as it poss can)
Any comments, made any massive mistakes, all the above is using 1/2" tubing setup, what would you change ?
EDIT: Oh also im trying to find a case that will accommodate 2 or 3 x 120.3mm radiators nicely and 7 or 8 hard drives easy, trying to find the large 'cube case' that some custom w/c company's use but no luck as yet, anyways any help would be awesome
Barb - Size: 1/2"
Barb - Size: 1/2"
Laing D5 Vario pump
Barb - Size: 1/2"
6 x 120mm 14db fans
