Check my 3dmark scores please.
25 Jan 2006
Gateshead, Newcastle
Hi,
im doing some tests with my amd rig as ive got a conroe rig in the making, so i have something to compare with. so... could you check my scores?
i have a X2 3800 at 2.7Ghz with Ram running at 225 3-4-4-8 1T
i got my x1900xt this morning and i did 1 test with the graphics at stock and one with it overclocked to 680/790
stock results were 5,662
overclocked results were 6,026
i'll do the same tests on monday in my new conroe rig, when my ram shows up.
Thanks,
StevenG
Sounds about right, I only had my X2 3800+ to 2.5GHz for benchies, and pretty sure I came in with about 5-5.5k......with a single 1900XT.....
Any chance of a 3dmark 2005 score so i can compare mine as well i cannot use 2006 on vista only 2005 at the mo cheers..
was near about 10k. ive got conroe now so i cant compare. i may have saved a screenshot but i dont know i'll check when i get home.
i did another test and it came out with a much lower result. with a fresh install of windows gets a better result
