14 May 2012 at 09:25 #1 bledd bledd Don Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown Just been moved to ADSL2 Anything I should change on this screen?
14 May 2012 at 09:52 #2 ANDARIAL ANDARIAL Soldato Joined 19 Oct 2002 Posts 7,452 Location Woolyback Country SNR enable and Phyre on up and down p.s. Lucky Bugger
14 May 2012 at 10:12 #3 lurkio lurkio Soldato Joined 20 May 2010 Posts 3,042 Location World your downstream SNR is only 3dB ... does your line drop much ?
14 May 2012 at 10:19 #4 bledd bledd Don OP Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown Never I live about 80M from the exchange
14 May 2012 at 18:10 #5 Sin_Chase Sin_Chase Soldato Joined 13 Jan 2004 Posts 21,316 That is some super low attenuation right there!
15 May 2012 at 09:48 #6 bledd bledd Don OP Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown Today it's Upstream 1279 Downstream 22158 SNR Margin(Upstream) 6.0 SNR Margin(Downstream) 5.2 Line Attenuation(Upstream) 6.3 Line Attenuation(Downstream) 8.5 Should I tweak my SNR, I've got a 7800N and it has this feature
15 May 2012 at 22:37 #7 Sin_Chase Sin_Chase Soldato Joined 13 Jan 2004 Posts 21,316 How long has the service had to adjust itself? My line is very stable so I tweak my SnR to 3.5dB to gain extra speed. If you do tweak keep an eye on stability (Loss of Sync etc) and keep an eye on the CRC and other error counters to make sure they are not too high. More speed does not mean more speed if you are doing too much error correction.
18 May 2012 at 11:18 #8 bledd bledd Don OP Joined 21 Oct 2002 Posts 46,860 Location Parts Unknown Seems the line is still settling Upstream 1279 Downstream 23824 SNR Margin(Upstream) 7.1 SNR Margin(Downstream) 2.7 Line Attenuation(Upstream) 6.3 Line Attenuation(Downstream) 8.5 It was literally about 15 mins before I made the thread that I was moved over to ADSL2+
