Check my build?
1 Nov 2002
Sussex
Ok so I was going to go with a Silverstone FT03, but after reading a ton of reviews, builds etc, decided to go with a 350, previously owned a 650, it was a nice case just a bit too big. 350 seems like a decent compromise between space, size and quality.
I wanted to go with Corsair ram (there is a Corsair theme running...) but I cant seem to find any that represents beter value compared to the Adata?
Already have a GTX 780 to go inside, hoping to go SLI when the prices come down again so I can max out that 144Hz;)
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £269.99
1 x BenQ XL2411T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £249.95
1 x Asus Z87 MAXIMUS VI GENE Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £169.99
1 x Corsair Professional Series AX 860W '80 Plus Platinum' Modular Power Supply (CP-9020044-UK) £162.95
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £155.99
1 x Adata XPG Xtreme v1.0 16GB (2x8GB) DDR3 PC3-17100C10 2133MHz Dual Channel Memory Kit (AX3U2133XW8G10-2X) £129.95
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £94.99
1 x Corsair Obsidian 350D Windowed Micro ATX Case - Black £86.99
1 x OcUK Professional Cat6 RJ45 10m Network Cable - Grey (B6-510) £5.99
Total : £1,349.70 (includes shipping : £19.10).
Do you need 16gb of ram? for gaming 8 is plenty most of the time.
Retail version of the cpu is only £6 more which gets you 3 years warranty and nice fancy box and a spare cooler.
I guess I don't need it, I just like to get the best I can afford where possible. Does Intel's warranty cover overclocking do you know?
