Check my bundle please, opinions appreciated !
2 Aug 2006
I'm looking at ordering this tonight..
Krypton Z77 660i" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel
- Cooler: Prolimatech Megahalem CPU Cooler w/ x2 Tech Labs Zaward 2000RPM 120mm Fan
- Artic Silver 5 Thermal Compound
And also adding a
OcUK GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card [NE5X67001042F]
Is there an equivalent or better AMD card in that price range ??
Also what Power supply would you recommend or will my seasonic s12 600w still be ok ??
Anyone know if that cpu cooler above will fit in a Fractal R3 case ??
Many Many Thanks
Hi there,
The Megahalem with have no problem fitting inside an R3 case.
The GTX 670 is a pretty damn good card. I would go for the gigabyte Windforce card as they overclock like stink, easily can boost to 680 levels of performance.
The seasonic PSU should be fine :)
