Hi guys
Put together new build. E6600, Gigaybyte GA P35C DS3R and OCZ 4GB (2 x 2GB) PC2-6400C5 Dual Channel Vista Gold Series and Noctua heatsink.
Despite running into troubles with Overclocking instructions (most guides listed modes in the BIOS that arent present on my board!) and software issues with temp software as I am running Vista 64 - I actually did some overclocking.
Got the E6600 up to 3.4 no probs. Suffered a few blue screens when I put the case cover on. Got the CPU working @ 350 x 9 = 3150 and is stable.
The temps are showing as:
Tjunction 85c
Core 0 idle 21
Core 1 idle 21
Core 0 load 36
Core 1 load 36
Memory timings are 6,6,6,16 at FSB
RAM 1.1.
I also had a go at clocking my graphics card which is a leadtek geforce 8800 GTS 640mb onto
700 mhz
1100 mhz
Which runs fine but gets a little hot. It never jumps more than 65c and idles in the 40's.
What do you think? These quite standard? or have I got something to worry about?
Tjunction 85c
Core 0 idle 21
Core 1 idle 21
Core 0 load 36
Core 1 load 36
RAM 1.1.I also had a go at clocking my graphics card which is a leadtek geforce 8800 GTS 640mb onto
700 mhz
1100 mhz
