- 18 Dec 2010
hi this is my first build,i already bought it.i just want to know if its all compatible together, and if it can max out everygame @1920x1080 resolution.
1X Thermaltake Dokker VM600M1W2Z Mid Tower Case W/Single Bay HDD Docking Station
1X Thermaltake TPX-775M ToughPower XT 775W PSU
1X Intel Core i5-2400 3.1GHz 6M/LGA1155 Original Boxed for
1X Asus P8H67 (REV.3.0) ATX (DDR3)
2X Kingston 2GB DDR3-1333 PC2-10600
1X WD 500GB WD5000AAKX 7200RPM S-ATAIII 16MB internal HDD for desktop
1X LG GH24NS50-24X DVDRW - Dual Layer SATA Black
1X Sapphire Radeon HD 6950 flex 2GB GDDR5 Eyefinity
1X Samsung PX2370 Wide 23" LED Monitor
1X Genius Xscroll Optical Mouse USB Black
1X Genius Slimstar 110 Black USB Water Resistant
1X 240 W. Speakers
1X APC SUA1000I 1000 VA Smart UPS
i forgot to buy fans for the dokker case, so it only has a rear 120 mm fan. can i live with only this one or it will cause lots of heat? what do you recommend.
1X 240 W. Speakers
