We're doing a home refurbishment and at the moment the ceilings have been taken down on the ground floor exposing the beams.
Upstairs hasn't had the new floor layed yet and is just wooden planks.
Before the builders finish the 1st floor this week by laying the new floor, I'd like them to route some cable for a basic home network setup for security camera's and networking.
I plan to have the router in the lounge, connect the router to a new RJ45 wall socket, have that cable run through the ceiling and then through the floor of the 1st floor airing cupboard into a network switch stored in there.
Cables will then run from there out to a front IP camera and a rear IP camera (which I believe I can power just from the CAT5e cable if it's POE?)
Also run a cable from the switch out to a new socket in the garage, and hook that up to the IP camera box to store the footage locally and allow us to view it.
I may also run one cable into the top bedroom for a hardline connection to a smart box, the walls have already been finished in the other bedroom and office, so I'm not fussed about running one there now.
Can anyone see any issues with this or suggest any improvements?
Thanks!
EDIT: Updated diagram
https://i.imgur.com/DkFrww4.png
Thanks!
