- 14 Jun 2011
- Wolverhampton
Hi guys can I have some advice on my settings.
Asus a8n-sli premium
AMD Athlon 64 x2 3800+ Manchester
I have managed to take it from 2.0ghz to 2.5ghz.
I have done the following -
CPU Multiplyer x10
HT Multiplyer x4
CPU Frequency 250Mhz
PCI - Locked at 100Mhz
DDR V - 2.8V
Chipset V - 1.5v (Default)
HT V - 1.2V (Default)
CPU V - 1.425 (But why does CPUZ show a different voltage?)
DRAM Config -
Memclock lowered to 333Mhz, still at 2T
Will run Prime95 for a good few hours and watch temps and check for errors, currently on standard cooler and it idles at low 40's
How much further do you think I should take it? 2.6, 2.7Ghz?
I dont fully understand the memory side of things as my PC3200 RAM is 400mhz and currently at 333mhz divider cpuz is saying its at 208Mhz so does this mean its at 416mhz? Dont know how far the memory can go, maybe if I continue I should lower the memclock further?
No idea about timings either and the difference between 2T and 1T im a complete noob to this..
Any advice would be great
CPU Multiplyer x10
HT Multiplyer x4
DDR V - 2.8V
DRAM Config -
