Check my power calcs and update please!
6 Aug 2008
Birmingham
Am I right in thinking to workout AMPs, I need to divide TDP by 12....
So for 768MB GTX 460's I am looking at
150 / 12 = 12.5 amps
I have 3 of these so 37.5 amps....
CPU is 980x oc'd to 4.2ghz..... What would be the amps on this?
Current PSU is 850AX, is this enough or should I go to 1200 with the option of adding in 1 more card?
850AX can do 70 amps...
This is a folding server BTW.....
I wouldnt chane it with that amount of hardware, PSU calculator recommends.
600w for a 980x rig with a single GTX470 and so your looking at a 1000w but I would recommend 1200w as a safety net.
Do you have a energy meter (Kill-a-watt) to measure the amount of watts your rig draws at the wall?
draws 300 when in full "fold"
Agree mate, im gonna order the 1200, better safe than sorry.
But if I could get away with the 850 that would be best!! lol
Youre assuming that the components run exclusively on 12v, which they dont. Power / 12 is a reasonable worst case scenario.
Cpu changes considerably when overclocked. Try
Code:
 power = tdp * (vcore/vid)^2 *(frequency / stock frequency)
as an estimate. Folding is hard on components, id want to overspecify the psu and get a single rail one.
Good man, team 10 is lucky to have you
sry for being dumb, how do i divide vcore by vid, are they not the same....
Could you demo for my cpu
TDP I think is 130...
Im volts 1.4
Frequency is 27 * 156 - 4212
Sorry about that, vid could well mean the same thing as vcore. By vid I meant the vcore when running at stock settings.
Its quite rough-and-ready, but measuring cpu power consumption directly is a bitch.
Assuming it's the 980X, not the Phenom 965,
130 x 1.4 x 1.4 / vid / vid x 4212 / 3330 :)
vid is probably 1.2ish which would give 225W, it'll be a slightly better estimate if you use your chips vid.
