Check my setup.
4 Mar 2011
Hey guys.
I want to know if you think the Cooler, PSU, Case, etc, is enough to keep this setup working smoothly, without any possible over-heating problems, etc.
Case
CoolerMaster HAF 922 or Antec 902. Still not sure on case.
CPU
Intel Core i7 2600k Overclocked at 4.8GHz.
Motherboard
Asus P8P67 Pro (Rev 3.0)
GPU
NVIDIA Geforce GTX 580 1.5GB
RAM
8GB 1600MHz
HDD
2x 1TB Western Digital Caviar Black 7200rpm
PSU
Corsair TX 850w
Cooling
CoolIt ECO A.L.C
Running Windows 7 64-bit.
But yeah guys, lemme know. This is my first gaming desktop.
Yes it will be fine, though personally I'd just get either an Akasa Venom or Titan Fenrir cooler, imo its not worth spending any more
Also re PSU, why 850W? If youre wanting to keep SLi option open then you want 1000W really, if youre not bothered about SLi in future you can get less, 750 easily still enough, if not 650, there are better PSUs available now than the old TX series, theyre still great, but look at the Antec-TruePowers or XFX-BlackEditions which are still made by Seasonic and are both Modular
Remove the competitor link before a mode see`s ;)
850W would be fine with SLI 580, I did run 2 on my 750w PSU with the spec belw my sig.
woahhhh competitor link.
That setup looks like it'll do the job well and 850W will be fine sa RJC said,
The haf 922 is an awesome case, i have it and it does the job spot on! very cold case :P
