check my site please
It's not loading anything at all. It's not an OS or browser problem, it's a problem with your web host. Maybe something to do with their ISP - That would explain why some people can see it and and some people can't. It would be the network routings across the internet not allowing users with certain ISPs to access your website. I've had the same problem before with one of my webhosts.
I suggest everyone who can't see the website also post what ISP they are using! (Maybe the same thing for those who can access the website too) - That way you can figure out what users can't access your website, and then let your host know. In the meantime, I would take the issue up with your webhost anyway, to see if they're aware that there is a problem.
My ISP is Virgin Media.
The main page loaded for me, but then no others did, I know you weren't asking for it but I've got a few comments to make, read if you dare, haha I took the 'check my site' thing literally.
The header image the font looks quite poor drop shadows and inner glows and all that faux-fanciness looks a bit dated now and detracts me from the site a bit, and I wish the clouds and sky in the background were a little bit brighter as you're not painting a great impression of the weather lol. I'm also not a massive fan of the navigation bar protruding the width of the page and the yellow font doesn't really suit it tbh. The drop down looks rather nice but then it doesn't follow suit with the navigation so that's a bit strange.
I really like the top right options, although there are quite a lot lol.
Then the main body isn't really that structured in my eyes, it's like you've put every single thing at once on the page which is a bit of a headbreak, the donate button is in a bit of a random place too, and do the bottom stats serve a purpose for people wanting to know the weather?
A plan for the site for me would be to do a mod re-write so that your urls get a bit shorter and easier to follow than all the gumpf you get at the mo.
Thanks for your comments, i have been using Joomla for making my site and the template i am using was already made. as for the rest of it i know that there maybe things that are not right but this was my fist go at a website and i used joomla because i hate html, i just can't get my head around it :(
i will change the yellow text and i think i can remove the menu on the top right, also i will see if i can lighten the cloud background.
