Check my spec before order
26 Dec 2005
Paisley
Been out of the game for a while, and Im building a new machine, is everything there compatible?
Shopping Cart (Prices in British Pounds)
REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£124.95 £124.95
GX-112-SP Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP)
£178.95 £178.95
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£144.95 £144.95
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£209.95 £209.95
CD-037-NE NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Silver) - OEM (CD-037-NE)
£19.95 £19.95
HS-020-ZA Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler (HS-020-ZA)
£28.95 £28.95
SY-002-AR Artic Cooling Accelero X2 Cooler (X1800/X1900 Series) (SY-002-AR)
£13.95 £13.95
HD-032-SA Samsung SpinPoint T HD300LJ 300GB SATA-II 8MB Cache - OEM (HD-032-SA)
£54.95 £109.90
Subtotal £831.55
VAT £145.53
Total £977.08
Look good to me although you really should get the Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO) Price: £169.95 (£199.69 Including VAT at 17.5%) which is cheaper that the sapphire.
Cheers didnt notice that.
Is the mobo/ram/cpu a combo that works okay without any conflicts (that was my main concern).
Ive also got a Antec P150 with 480w antec psu, is that going to be man enough to power that?
hey nice to see ;)
combo is good, the 975X boards best suits a conroe.
im not a real fan of the zalman cooler, have you looked at the sythe and others?
Antec should be fine with a single xt
The board is crossfire compatible, you'd need an X1900 mastercard to go with the X1900 and a new PSU too.
If it was me I'd swap the hard drive for a Seagate 7200.10 and go for the HIS X1900 XT ICEQ 3 instead.
