Check My Spec Before Purchase..
29 May 2005
hey. can you lot give me your views on my specification before i hit the all important buy button.
my price range was £1000-£1200 but I don't really know what to swap in and out to make it better.
is the DD3 thing worth it? is this memory the best i can get? any better graphics cards available? this one seemed to be a winner at the time.
thanks , mo :D
I would definately change the Q6700 for a Q6600 or E8400?
The psu & ram wouldnt be my 1st choice either
Are you gonna be overclocking?
OK. which one do you recommend, the Q6600 or E8400?
Which PSU and RAM would you suggest? :)
I could over-clock yeah, but probably wont do it straight away.
Some say the E8400 is better for gaming as it clocks more but id personally go quad for more future protection, something along these lines
i'd go with most of tatts spec but unless you want to order straight away i'd change the psu to the Thermaltake ToughPower 850W.
nowt wrong with the corsair 620w either.
Totally agree, i was looking for in stock items as i thought he wanted to order asap?
Nothing wrong with the corsairs, i was just trying to give a little headroom incase crossfire is a future option :)
