Check my spec? :D
30 Jul 2011
Kk, Ill change to:
Gigabyte Z68XP-UD3P Intel Z68 (Socket 1155) DDR3 Motherboard
Actually if you are not on a tight budget, stretch a little further to what fowler002 suggested above (yea I know it's quite a bit more expensive than initially), as it has PCI-E 3.0, as well as better onboard sound 8 Channel HD Audio with THX TruStudio Pro instead of typical Realtak. If you are not stretching, for the £105 board I think you would be better with the MSI in the two I quoted above, as the Gigabyte is only a Micro-ATX board with fewer slots, whereas the MSI is full size ATX board, and the spacing between the two PCI-E x16 slots is wider (so more space for air-intake if you do go SLI).
the gigabyte you linked to is matx, the z68xp-ud3p is £119.99(no idea what the difference betwen it and the cheaper z68xp-ud3(£109.99) is) and atx.
z68xp-ud3p http://www.overclockers.co.uk/showproduct.php?prodid=MB-360-GI&groupid=701&catid=5&subcat=1990
z68xp-ud3 http://www.overclockers.co.uk/showproduct.php?prodid=MB-368-GI&groupid=701&catid=5&subcat=1990
