Hi, I posted a spec me thread a few weeks ago but have sincce gone down the rabbit hole a little bit and have effectively upped my budget, so feels better to start a new
Please have a look below and suggest any changes. I would be very happy to spend less if this is overkill.
I know the processor has had so so reviews and tempted to go down to 7700x or 7900x but the little discount helped me put it in the basket.
Should i go for the XT rather than the XTX? is there enough benefit at 1440?
PC is everyday work PC just running MS Office but usually with a lot of apps open at the same time
Gaming at 1440 ultra wide (currently playing FC 6 and Hogwarts)
I tend to build (which I enjoy) but then run the same spec for a long time. 6 years on my current vega 64 build (which still runs well to be fair)
Anything you wouldd adjust, down in price preferably, but up a little is OK, preferably sticking to all AMD (but not firm) and I like the case and fans
THank you lovely people very much in advance!
I need to buy before month end so i'm in a hurry!
My basket at OcUK:
My basket at OcUK:
- 1 x AMD Ryzen 9 7900X 3D Twelve Core 5.60GHz (Socket AM5) Processor - Retail (SKU: CP-3DS-AM) = £589.99
- 1 x Sapphire Radeon RX 7900 XTX Nitro+ Vapor-X 24GB GDDR6 PCI-Express Graphics Card (SKU: GX-3A4-SP) = £1,178.99
- 1 x AMD Radeon™ Get The Game Bundle - The Last of Us™ Part I (SKU: XX-03D-AM) = £0.00
- 1 x Asus ROG Strix B650-A Gaming WIFI (Socket AM5) DDR5 ATX Motherboard (SKU: MB-6JY-AS) = £283.99
- 1 x Thermal Grizzly Conductonaut Liquid Metal Thermal Paste - 1g (SKU: TH-021-TG) = £9.95
- 1 x Thermaltake The Tower 500 Snow Mid Tower Case (SKU: CA-1B6-TT) = £199.99
- 1 x TeamGroup Delta RGB 32GB (2X16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit - White (FF4D532G6000HC30DC01) (SKU: MY-0B6-TG) = £169.99
- 2 x WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T2X0E) (SKU: HD-591-WD) = £149.99
- 2 x Lian-Li GALAHAD AIO SL 360mm High Performance RGB CPU Water Cooler - White (SKU: HS-00D-LL) = £169.99
- 1 x Lian-Li UNI SL140 Addressable RGB White 140mm Fan Dual Pack with Controller (SKU: FG-00M-LL) = £39.95
- 2 x Lian-Li UNI SL120 Addressable RGB White 120mm Fan (SKU: FG-00F-LL) = £22.99
- 1 x **B Grade** Lian-Li UNI SL140 Addressable RGB White 140mm Fan Dual Pack with Controller (SKU: BG-08D-LL) = £29.99
- 1 x MSI MPG A850G PCIE5 UK PSU 850W 80 Plus Gold Modular Power Supply (SKU: CA-00Y-MS) = £129.95
- 1 x WD 3TB Blue HDD 5400rpm 256MB Cache Internal Hard Drive (WD30EZAZ) (SKU: HD-57R-WD) = £89.99
Total: £3,408.72 (includes delivery: £0.00)
SAVE 11%
£190
(incl. VAT)
£170
(incl. VAT)
FREE DELIVERY
£10
(incl. VAT)
SAVE 7%
£140
(incl. VAT)
£130
(incl. VAT)
£100
(incl. VAT)
