Check My Spec Please
27 Jun 2006
Leicester
I'm looking to build a pc for the first time. It'll be mainly used for gaming and the internet. I only have a 19 inch monitor not some huge monster so am I correct in think 512mb on the gfx card would be a waste?
I'm hoping this build is upgradeable, crossfire etc.
Also I'd appreciate it if you'd let me know if there is anything I've totally missed.
I don't plan on doing any overclocking (not without a hell of a lot more research :p ).
Thanks in advance.
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN) 1
£214.95 £214.95
MB-010-IN Intel Extreme D975bx-304 975X (Socket 775) PCI-Express DDR2 Motherboard - OEM (MB-010-IN) 1
£129.95 £129.95
MY-001-PA Patriot Signature 2GB (2x1GB) PC5300 667MHz DDR2 Dual Channel Kit (PSD22G667K) (MY-001-PA) 1
£119.95 £119.95
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) 1
£136.95 £136.95
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE) 1
£52.50 £52.50
CD-020-AS Asus DRW-1608P3S 16x16 DVD±RW Dual Layer ReWriter (Black) - Retail (CD-020-AS) 1
£24.50 £24.50
CA-069-LL Lian-Li PC-S80B Black Aluminium Full Tower Case (CA-069-LL) 1
£148.95 £148.95
CA-046-AN Antec NeoHE 550W Modular ATX2.0 PSU (CA-046-AN) 1
£74.95 £74.95
Subtotal £902.70
VAT £157.98
Total £1,060.68
Im sooo embarassed! :o
there's a cheaper g-skill 5300 or there's a g-skill 6400 ram for approx the same price.
also i was told stick to like plextor/nec/some other one i cant remember for the optical drive. although i'm not sure if that was the person's personal preference or because it was good
I'd go for a Tagan or Seasonic PSU myself...
Dont know if anyone would agree but from preference id say they're better :)
s-
Budget is kinda flexible but I was aiming for about a grand excluding monitor and peripherals. Money is there for improvements if the represent value in performance vs cost.
Only thing id suggest is either the Conroe E6700 (2.67ghz) or the X1900XT, but its still a great rig.. it just depends on what games you play really...
Dunno if you've decided on the monitor, but id go for the DELL 24" :D
s-
Stelly said:
Would change the RAM to Gskill though...
That looks really good to me as well :)
Well done :)
Stelly
I agree, i was waiting for someone else to say something first though, i dont know much about RAM
But wouldnt he want to have GEIL or something instead of G.Skill as they're generally better for overclocking?
Not sure though
s-
Think its unlikely I'll be trying to overclock anything for a while. Just thinking about building the thing is giving me a connery :p
If you're not going to overclock, id step up the Conroe to the 2.67ghz one, you dont have to but would give it a hell of a boost..
If not, id change the graphics card :)
s-
