check my spec pls guys
18 Dec 2007
YOUR BASKET
1 x OcUK Tech Lab H2O Custom GTX 670 2048MB GDDR5 £320.98
1 x EK Water Blocks EK 670 Full Cover Waterblock - Nickel Plexi £73.98
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) ** Cash Back Promo ** £139.99
1 x MSI Z77A-GD65 Intel Z77 (Socket 1155) DDR3 Motherboard £119.99
1 x XSPC RX360 120mm Radiator - Black £89.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x XFX 750W XXX Edition Modular '80 Plus Silver' Power Supply £83.99
1 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £59.99
1 x EK Water Blocks EK-Supremacy - Nickel £56.99
1 x Laing 10W DDC-Pump 12V DDC-1T £54.98
1 x Corsair Carbide 200R Compact ATX Case - Black £49.99
1 x EK-DDC X-RES 140 CSQ - Acetal £41.99
1 x Hardware Labs Black ICE Radiator GT Stealth 120 £27.49
3 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99 (£77.97)
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Single Pack (CO-9050011-WW) £14.99
1 x Mayhems Aurora - Nebula Blue Coolant 1L £14.99
2 x Mayhems Aurora - Nebula Blue Concentrate 250ml £11.99 (£23.98)
1 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear £5.99
1 x Akasa FLEXA FP5S 5 Fan PWM Controller (AK-CBFA07-45) £5.28
1 x Akasa FLEXA FP5, Smart PWM cable for 5 PWM case fans. (AK-CBFA03-45) £4.79
6 x Akasa PWM Fan Extension cable - 30cm (AK-CBFA01-30) £2.99 (£17.94)
12 x EK 12mm (1/2") G1/4 High-Flow Barb Fitting £2.96 (£35.52)
Total : £1,611.96 (includes shipping : £13.50).
hey guys this is a spec im looking at building pls no comments on the case as i have some big plans for it modding wise and idont want to spend 200 pound on a case and mod it encase i fk it up :p
but are all the water cooling bits OK ? i got a 360 which i know i can fit in the front of the case
and also a 120 to go on the back of the case with an exhaust fan
loop will ok 360 rad to pump/res combo to GPU to 120 mm to CPU to 360 mm
will this work and do i have enough cooling for good ocs on my system
And will the 120 help the temps at all or should i not bother ?
another question i would like to get some like 40 degree bend barbs ive seen them on videos but i cant find them on overclockers ? any advice?
thanks in advance guys
Here is an example so it may help you more experienced guys help me on what fittings i will need
Uploaded with ImageShack.us
again thanks in advance for any help
so the fluid will not cool the system ?
so what do i need to buy to use those angle fitting does the tube fit right on them ? sorry it my first watercooling build im still not to sure on the fittings ect
so i dont need barbs with these fittings ?
the rotaries looks good can i just connect the tube right to them and they fit into the holes in the rad and gpu cooler and the cpu cooler and the pump and res /
also what blocks do you recommend ?
will the 120 not do anything ? its more for the look tbh
thanks for the help
Yeah, but it's not meant to be used for extended periods. It'll lose it's sparkle when the pearl settles and could also lead to clogging.
No, you attach your barbs/compression fittings to the angled rotary.
The block is fine, it's just that some people don't like the looks of the CSQ range.
It won't hurt, it just might not do much in terms of lowering temps.
If you want it for the looks and whatever temp help it may offer, go for it
I'm using the phobya equivalent of that EK rad and running the same GPU with an old bloomfield i7 (much hotter) and my temps are fine. The extra 120 is probably overkill and you're not likely to see as much benefit from it due to it exhausting already hot air over the rad.
As for fittings, it's personal preference imo. I've read good and bad about rotaries and personally managed to get 2 doa 90 rotaries (EK ones) but once I got them RMA'd and replaced they worked perfectly in my loop and it makes things a lot easier to work with.
thanks for the replys guys could i use these fittings ?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-211-BP&groupid=962&catid=1529&subcat=1852
also what the easiest way to make the 6 fan cables tidy ? im dreading a mess of cables to feed all them fans any ideas ? and shall i get PWM fan or normal one what's the real difference what will be est for my mobo
thanks for all the help guys
You could get two of these and stick them on a fan controller. Feed the cables through the back of the motherboard tray and hide them.
http://www.overclockers.co.uk/showproduct.php?prodid=CM-094-BX
Could be a better way, but this is what I've done.
Agree on the 120 not being needed, also you appear to have gone pretty overkill with fans there, by comparison my system has a GTX670 FTW edition with EK full cover block and an i7 3820 OC'd to 4.5GHz with EK Supremacy, my cooling consists of a thick low FPI 360 rad (like the one youve have selected) with one of the fans you have selected and two 500RPM Scythe kaze fans on it.
The highest my CPU temps ever go is mid to high 50's and that's after hours and hours of gaming, sometimes if the central heating is on full it may reach 60 however this is only because I have my mobo set to run the SP120 PWM at ~600rpm until the temps hit 65 degrees (which they never do) then ramp up (my folding/Prime temps are fine). The highest my GPU has never gone is 58 degrees after gaming for practically the entire weekend.
How are you planning on fitting a 360mm rad in that case without heavy modding?
I think its a mad way to go when you can pick up the switch 810 on two for 130 quid that will take the 360 and a 240 easy with no modding required just screw straight in
Personally id ditch the case in favor of the switch ditch the aurora in favor of pastel blue ditch the single 120 in favor of a 240 for the front/bottom and scrap push pull with those fans you dont need it
here
YOUR BASKET
1 x Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) ** Cash Back Promo ** £134.99
1 x NZXT Switch 810 Big Tower Case - Matt Black £129.98
1 x OcUK Tech Lab - 10w DDC Pump & EK-DDC X-RES 100 CSQ Value Combo £89.99
1 x XSPC RX240 120mm Radiator - Black £68.98
2 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99 (£51.98)
2 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99 (£29.98)
Total : £1,642.27 (includes shipping : FREE).
No modding enough cooling to go sli in the future if you wanted its basically all plug and play and if you wanted you could save nearly 30 quid by fitting the graphics block yourself
Personally id also add a fancotroller too something like this
http://www.overclockers.co.uk/showproduct.php?prodid=CA-072-BX
to keep the fans ultra quiet when idling
Lastly if using a fan controller id ditch the low noise versions of the fans you dont get anywhere near the same static pressure compared to the full strength versions
