- 13 Sep 2005
- Crewe,Cheshire
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Corsair 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle £599.99
Options applied to the above product:
3.80GHz Overclock £0.00
XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card £218.99
Corsair HX 650W ATX Modular SLI Compliant Power Supply (CMPSU-650HXUK) £96.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £61.99
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) £34.99
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM £19.99
Sub Total : £898.21
15% VAT : £136.23
Total : £1,034.44
Max budget £1200
Im putting all this into a p182 case with a xfi sound card i already have, couple of questions should i take the Corsair Tx 750w instead of the Hx 650 to give myself some future proof wattage wise. The reason ive gone for a pre overclocked bundle is i dont have the free time to spend clocking it myself and im fairly lazy
Also the Hdd's the smaller one is for windows 7 and my games as that is the going to be the main use of the pc and the larger being for storage not sure i need 1Tb but since when did that stop anyone. Is this the best way of doing it or should i just partition the 1tb and use it for everything, maybe waiting till i can grab a SSd at a fair price ?
Wondered if someone could recommend some nice quiet fans to as replacement for the ones i have in my case there 120mm x 2-3. Any other feedback is welcome im gonna be ordering this before the end of today hopefully.
Sub Total : £898.21
15% VAT : £136.23
Total : £1,034.44
Max budget £1200
.Also the Hdd's the smaller one is for windows 7 and my games as that is the going to be the main use of the pc and the larger being for storage not sure i need 1Tb but since when did that stop anyone. Is this the best way of doing it or should i just partition the 1tb and use it for everything, maybe waiting till i can grab a SSd at a fair price ?
