Check my spec
30 Aug 2006
Im building a pc for my sister, shes going to be doing some light gaming on Sims 2 and she doesnt need a DVD drive or a monitor.
BFG GeForce 7600 GS OC 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail
£71.99
(£84.59)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM
£93.99
(£110.44)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
£84.99
(£99.86)
Corsair 1GB DDR2 Value Select PC4200 Dual Channel Kit (2x512MB)
£64.99
(£76.36)
Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM
£25.99
(£30.54)
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU
£66.99
(£78.71)
Total : £492.20
The only thing Im worried about is whether the mobo is compatible with the memory, Ive heard the DS3 as well as other Gigabyte boards have some compatibilty problems.
Yeh i think that corsair should be fine! The problems with compatability were due to the bios which i think have been ironed out! ;)
