Check my spec
28 Dec 2003
Looking at building a new machine for the gf. Needs to be able to run the latest games and last a few years before replacement. Will never be overclocked and stability is a major priority. She also doesn't need a monitor, speakers, keyboard or mouse as she's perfectly happy with the ones she has.
To this end, this is my proposed spec:
Intel Core 2 Duo E6600
Abit AB9 Pro
Geil 2GB (2 x 1GB) PC5300 Value DDR2
BFG GeForce 8800 GTS OC 320MB
Seagate Barracuda 7200.10 320MB SATA-II
Pioneer DVR-111BK
Creative Sound Blaster X-Fi Extreme Music OEM
Coolermaster Wave Master Black
Akasa Ultra Quiet 500W Paxpower Active PFC
MS Vista Home Premium 32-bit OEM
Items I'm currently unsure of are the motherboard and memory so I'd appreciate any advice on these or better options to go for. Cheers.
CPU - good, although you could overclock the much-cheaper e4300 or e6300 to the same speeds for much less money. I'd go with the e4300.
Mobo - I'd go for the Asus P5N 650SLi, Asus P5B, Gb DS3/4 in that order.
RAM - go for the PC 6400 RAM.
GFX card - Perfect
HD - Samsung or Hitachi are better, make sure you get SATA 2 / SATA 3GB and a big cache.
DVD - perfect
Sound - on board should be sufficient, so save money here.
Case - I'd go for an Akasa Eclipse
PSU - Corsair, Seasonic, Enermax, in that Order. The Corsair 520W is the PSU de jour
OS - Perfect.
Hope that helps. Please let me know if you'd like me to elaborate on anything.
Seagate HDDs are class mate... top notch... I wouldnt agree with melbourne720 about the HDD... sorry mate :)
Stelly
Stelly
Fair enough, you live you learn. :) The rest of the spec would fit the needs of the OP though...
Cheers for the input. As I said, overclocking isn't an option so I figured the E6600 is the best bet.
Mobo-wise, what are the main benefits of the boards you suggest over the Abit one? Bear in mind there's no overclocking requirement here and I was under the impression that, if you're not after such overclocking features, all boards performed pretty much on a par so it's just a question of what other features you want.
Memory - I'm sure I read somewhere than the C2D systems don't benefit that much from faster RAM, is this the case or would PC6400 give a real benefit?
Sound - having seen the enormous benefit an X-Fi gave my system over on-board sound I'm inclined to go this way. The more expensive mobos seem to have full 7.1 on-board, how does this compare with a separate card like the X-Fi?
Case was just something I quite liked the look of tbh - I think it'd end up being a case (no pun intended) of what she prefers the looks of :)
PSU - noted, ta
It has all the same features and it is £10 cheaper?
I think it is that the C2D systems don't benefit from tighter (faster) memory timings. AMD CPUs do but C2D work best with looser timings and faster memory speed.
Not really a sound expert, but I am perfectly happy with my onboard sound. It is HD (like on the 650 board) and goes through two boston acoustics speakers and a sub. Sounds really good. Up to you really.
PSU - noted, ta
Fair enough, and pun excused ;)
