i posted earlier in the week, have decided to up the budget slightly to accomodate for better graphics card, so i dont have to upgrade again for a while..... rather then buying x1950pro and then buying a new card later on.....
does this sound all good??? i matched the processor and ram for overclocking potential later in computers life...
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail
G.Skill 2GB DDR2 NQ PC2-6400 (2x1GB) CAS5 Dual Channel Kit
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 quick questions.....
does vista 64bit still support most of the stuff xp does games wise, i know about drivers and have found 64bit ones for the appropriate hardware......
also i have a X-PRO 460W PSU, without overclocking anything will it be ok do you think?? will be running 1xdvdrw 2xhd and a couple of usb things, webcam, card reader....
cheers again for any help,
