Check my spec!
19 Aug 2003
North
Opinions wanted!
I would like to cut the price by £100 if possible but not too fussed, any suggestions/alterations?
Cheers
I would remove the keyboard. Not that it is bad but because it is £64 :p
Other than that it is a good spec. Wait for other people to comment because they might have other suggestions. :)
Thanks, it is an expensive keyboard although i use my projector a lot so a backlit KB would make me very happy when typing in the dark. :D
I am worried the motherboard may not be suitable if anything
I guess thats a plus :D
Good spec then. That processor is going fast because at £105 is a steal. :cool:
They're good, but depending on how much you want to save £100 you could leave it out, other HDDs like the Samsung F3 are still pretty quick.
Thanks for the advice peeps. The SSD is a big cost considering i have lots of spare drives at home, ill think ill save that for a later date.
