- 4 May 2004
I'm doing my 3-yearly pc overhaul upgrade. I haven't got a budget specifically but I try to keep every component under £100 to get best bang for buck.
RAM:
I read that the D9 Micron chips used on Ballistix die after around 8 months of running at high volts. Will this be a problem if I run them at the rated voltage of 2.2v? :S
Given that I could reach 3.0GHz at 333MHz * 9, (@DDR667) should I get the cheaper Geil RAM as it won't even be overclocked when running the CPU at 3GHz.
GFX:
As I was adding items to my basket the 1950 pro with Zalman dropped by £10 to £105.
I am slightly temped by an OcUK value 8800gts but can't convince myself that spending an extra £70 will get me £70 worth of performance.
DVD RW:
Its SATA so frees up a PATA channel
MOBO:
Does having 1 IDE channel mean I can run 2 IDE drives? I'd like to be able to run 2 of my old PATA hard drives, my new SATA hard drive as well as the DVD R SATA drive.
HSF: How far could I take the 4300 with stock cooler? Are the stock coolers any good/quiet? Can anyone recommend a quiet aftermarket cooler?
CPU: I think I read somewhere on OcUK that the newer 4300s dont clock as well as they used to?
Will there be any cables or bits & bobs I might need? Will everything fit? Anything I have forgotten? I already have a monitor (19inch) and HDD.
I also have some 3 year old AS5 somewhere. Will it have 'gone off' by now?
Thanks!
RAM:
GFX:
DVD RW:
MOBO:
Thanks!
