check my system build
5 May 2013
I am wondering if the graphics card is more than I need for running current games like COD black ops at 1920 x 1080, is there a less expensive card that can give me a good quality and decent frame rate?
My original budget was circa £750 but I decided that I would be better off with the i7 rather than the i5 as I do some photo and video editing, I also thought it would make the pc much more future proof. So I saved a bit longer and upped my budget to £900.
I was going to use a Corsair GS600 psu but as the price of the Antec EA 550w '80 Plus Platinum' psu was only slightly dearer, I think it will reduce my energy consumption.
Overclockers uk
"Quasar 215i" Intel Core i7 4770K @ 4.2GHz Overclocked Haswell Gaming PC Bundle ***With a Free copy of Medal of
Honor: Warfighter and Grid 2*** "Quasar 215i" Intel Core i7 4770K @ 4.2GHz Overclocked Haswell Gaming PC Bundle
***With a Free copy of Medal of Honor: Warfighter and Grid 2***
£449.99
Antec EA 550w '80 Plus Platinum' Power Supply Antec EA 550w '80 Plus Platinum' Power Supply
£69.98
Total : £531.97
Kingston 60GB SSDNow KC300 SATA 6GB/s 2.5 Kingston 60GB SSDNow KC300 SATA 6GB/s 2.5" 7mm Solid State Drive
Pioneer DVD-RW 24x SATA Internal - Retail Box Pioneer DVD-RW 24x SATA Internal
XFX ATI Radeon 7870 1GHz 2GB PCI-Express 3.0 HDMI Core Edition XFX ATI Radeon 7870 1GHz 2GB PCI-Express 3.0 HDMI
Seagate Barracuda 7200.14 2TB Hard Drive (7200rpm) SATA 64MB (Internal)
Microsoft Windows 7 Home Premium 64-bit (SP1)
1.5m HDMI v1.4 to HDMI v1.4 Cable
45cm SATA Data Cable 3 x £1.02
Total price £915.22
Thank you for your post.
I definitely like the look of the psu you suggested but will probably go for the 550w version.
I'll stick with the pioneer dvdrw as I have had one before that read every brand of dvd I threw at it, unlike the samsung I have now which is useless.
I will also stick with an ocuk bundle as they are very good value.
I know that at the moment there aren't many applications that benefit from hyper threading but I am trying to avoid an expensive mistake by going for the i5 and later finding that I should have got the i7 because software writers have caught up with the newest cpu's.I also like to be able to render video and still be able to work on the pc
I don't need a new case as I got rid of my old beige box and bought a Zalman Z9 last year.
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail with FREE Grid 2 PC Game £275.99
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £173.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard + FREE Be Quiet! Shadow Rock Pro SR1 CPU Cooler! £109.99
1 x Toshiba SSD HG5D Series 7mm 128GB Solid State Hard Drive - (THNSNH128GCST) £94.99
1 x Avexir Core Blue Series 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16001008G-2CW) - Blue Light £89.99
1 x **B Grade** Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (S (HD-255-SE) £62.40
1 x Thermaltake Smart Series 530w Modular '80Plus Bronze' Power Supply £49.99
1 x LiteOn IHAS124-04 24x DVD±RW SATA ReWriter (Black) - OEM £20.99
Total : £890.33 (includes shipping : £10.00).
You can use the Windows 8 Evaluation Edition for free on a 3 month trial. Windows 8.1 should get a preview too you can try.
A semi modular PSU is really a must in the Z9 chassis (I own one). This 7870XT is a Tahiti core so is related to the 7950 (snips didn't use one it's really worth the slight extra cost), OC it and you are trading blows with a stock 7950. 16GB of RAM which has good OC potential. HDD is B grade but does save around £20. Mobo includes a cooler and has 4 sata cables inc. The optical is good (I own one) OCuk inform me it's still the B revision that can be cross flashed to become a iHAS-524 and unlock the extra features.
[QUOTE
A semi modular PSU is really a must in the Z9 chassis (I own one). This 7870XT is a Tahiti core so is related to the 7950 (snips didn't use one it's really worth the slight extra cost), OC it and you are trading blows with a stock 7950. 16GB of RAM which has good OC potential. HDD is B grade but does save around £20. Mobo includes a cooler and has 4 sata cables inc. The optical is good (I own one) OCuk inform me it's still the B revision that can be cross flashed to become a iHAS-524 and unlock the extra features.[/QUOTE]
I have made a few changes to my spec after following some of the advice given in this thread but am not 100% sure on the psu, I have a Zalman Z9 case with the psu mount at the bottom,so am concerned about cable length. so any advice on psu's and cable lengths would be appreciated.
"Quasar 210i" Intel Core i5 4670K @ 4.2GHz Overclocked Haswell Gaming PC Bundle ***With a Free copy of Medal of Honor: Warfighter and Grid 2*** £374.99
XFX Pro 650W Core Edition '80 Plus Bronze' £64.99
Total : £451.98
Sandisk 128GB SSD SATA 6Gb/s £69.99
MSI AMD Radeon 7870 1050MHz 2GB PCI-Express 3.0 HDMI OC MSI
£168.39
