- 26 Aug 2012
- North West
Ok my system is setup as below (yes my art skills are amazing)
http://i.imgur.com/GFf3V.png
My Idle temps are around 38-45 degrees now for all cores, with an overclock at 4,5ghz . Under max load my temps never exceed 65 degrees on any core under prime 95 or intel burn test.
These results are at quietest fan settings. I get about 10 degrees lower if I put fans to mid speed. However, unless at minimum speed the fans sound like 2 jumbo jets, would you say these temperatures are good enough for 24/7 ?
