- 4 Dec 2009
- Worcestershire
I am new to watercooling but I have done a build with a friend and have read the various guides over the internet. Even so, could you guys just check over the following gear to make sure I haven't made a noob mistake (i.e. mixing metals that shouldn't be mixed etc.)
It will be cooling a 5850 and a Phenom II 955
So, my parts are......
EK-FC5850 5850 CF - Plexi (copper)
EK-Supreme LT AMD - Plexi (754/939/AM2+/AM3) (copper)
1/4" BSPP - 1/2" Hose Tail XSPC - Chrome
Nanoxia (Phobya) Hyperzero ReadyFluid - UV Red
1/2" ID - 3/4" OD XSPC Clear Hose 1m
Hardware Labs Black Ice® GT Stealth 280mm Dual Radiator (brass and copper construction)
XSPC Dual 750 Bay Reservoir & Pump
Can you spot anything I need to add/change?
Thanks
Thanks
