check out my loop :)
18 Jul 2012
Nottingham
here is my loop in my current system :)
its my first loop :)
what do you think?
Is that tube coming out the bottom of your res a bit kinked (the one at the front)? Also how do you know if your system is fully bleed when your using solid colour lines?
tbh when i have done that ive always run the system with a full res first then tipped it on all sides then bled it before creating an airgap in the res normally get all the air out fine but yer it is a little harder to judge with solid tubes
