Check Serial number on Processor
Permabanned
19 Nov 2019
hello i have a question is thier a program or a way to check proccessor serial number without opening or taking of the cpu cooler?
Intel once implemented it with Pentium 3's but there were massive privacy concerns at the time and so it was soon dropped.
The box is probably your only option if you don't want to take the cooler off.
Depending on where you bought the processor they sometimes note the serial number on the invoice, otherwise you will need to remove the cooler and physically check
