I am quite confident in the component choices for this build, but I would like some feedback just to make sure.
Case: Antec DF85
Mobo: Asus P8P67 Deluxe
RAM: 8GB Corsair Vengeance 1600MHz dual channel
CPU: i5 2500K
Cooler: Prolimatech Megahalems Rev B with 1x 120mm Akasa Viper fan
Graphics: 2x Sapphire ATI 6950 2GB - xfire
PSU: Corsair Enthusiast Series 850W
HDDs, OS and optical drive are already accounted for.
The plan was to get the best gaming performance with enough performance elsewhere for the usual for under £1200, the components above come to a total of £1148. The PSU might be slightly overkill but it leaves enough overhead for overclocks on the CPU and graphics cards with plenty to spare for a bunch of HDDs. I also made sure that there will be clearance between the two graphics cards and the case certainly provides more than enough airflow though it has more outflow than inflow... The side hole for the optional fan will suck some extra air into the gpu area which can't be a bad thing but there is no dust filter there, oh well.
Any feedback will be appreciated.
Case: Antec DF85
CPU: i5 2500K
