Could I just get the thumbs up from you lot on this spec before I click the magic buy button?
I've been away from desktops for some years (last one I built was back in ~2000 which was an Athlon 850 OC to 1Ghz on an Abit KT7A - what a machine!) and obviously so much has changed since then so there's been a lot of reading to do.
Only PC I've been using for the last 6 years or so has been my pentium m banias 1.5 laptop but now I need a proper desktop again with some reasonable oomph. Will be doing CAD and some games like L4D and MW2 on it.
I've based the build on the £700 AMD build in 95thrifles' 'choosing your components' thread (extremely helpful, thanks!) but changed a few bits to my preference/TWO offers
I've gone for the phenom II dual as it's very good value and I dont think I need a quad. Not really looking to overclock necessarily however I can have a go at unlocking the other 2 cores - if it works then that's a bonus but if it doesn't work, then no bother really.
I already have a keyboard and monitor I want to use.
Just wanted to check if there are any issues with this combination of components or if there are some better alternatives I could use instead?
total inc. VAT = £757.63
I might personally have tried to head down the intel route, but it looks like you have a good idea of why you want those components.
