- 12 Jan 2006
Just a couple of queries as its nearing the time when i start putting all the bits together,
according to the guide i should add some ink/food colouring to the water so when it leaks it will show up on the white paper towels below.
But wont this put imprities into the loop? which is was the whole point of using vinegar and cleaning stuff out etc?
Secondly is there any way of turning the PSU on without plugging it into the motherboard to test the loop outside the case?
or does it all have to be plugged together with a board and psu sitting beside it
Thanks in advance
Thanks in advance
