Checking if a Port is open without Telnet installed
12 Oct 2005
Surrey
Question specific to ESX Server:
How can we check if a port is open if telnet is *not* installed?
Would be handy if you someone could specify the right syntax also.
Regards,
from the esx server that you want to query...
Code:
# esxcfg-firewall -q
Will show what is enabled. The esx firewall is just a wrapper for iptables though...
Also, bear in mind - this is for VI3, and that iptables is configured to drop by default.
EDIT: You could also use netcat or nmap... but you'll have to either compile them yourself (no biggie), or find an rpm for RHEL3 and install that.
