Hello,
I have always wondered this so thought I would finally find the answer.
Basically, my driveway is a slope and so is my road.
They are not massive hills as such but decent slopes.
What sort of effect does this have on measuring engine oil level? I know ideally you want a flat surface.
Also, with regards to checking oil how long should the car be stood with the engine off (it is an engine-off oil check car, not all are) before an accurate reading can be taken.
Thanks,
Chris
Thanks,
Chris
