Checking panel revision on Dell screens
24 Jul 2004
Devon, UK
Just a quick question, what's the button combination to check the screen revision on the Dell 2007FP?
I'm sure i've seen it mentioned before, I just wanted to check I do actually have A04 as I got it off a private seller. :)
the revision should be listed on a sticker on the back, not through the OSD factory menu
however, to get into factory menu on the 2007WFP:
To find out which version of the 2xx7 you have:
1- Turn off your screen
2- Press simultaneously the 'Menu' and '+' button of the screen.
3- While holding the 2 buttons, press now the 'Power' button.
4- Once the screen in ON, unpress the 3 buttons.
5- Just press '-' button.
http://www.tftcentral.co.uk/articles/dell_panel_lottery.htm
