When I only had one card installed I was able to right click on the desktop and check card temp on the nVidia menu. Now that i'm running SLi, however, I've lost this option on the menu. Any idea how I can do it?
I still have it in the Nvidia menu. Right click>properties>settings>advanced>7800GT (or whatever you have)>temperature settings. Drop down menu for Gpu1 or Gpu2. I do have coolbits installed so not sure if that makes a difference.
What driver version are you using. 84.21 is the latest official driver. Get it here.
