Anyone here a CheckPoint guru and has knowledge of R80.10 yet? I won't go into masses of detail but I am looking for help on the following scenario:
I had a 2 node ClusterXL R77.30. The secondary node died and I had to re-install it from scratch. I decided this was probably a good time to upgrade to R80.10.
Now I have 1 primary ClusterXL R77.30 node that is production and a R80.10 node that thinks it is the primary member of a ClusterXL and is running Security Management Server.
Sooooo, I need to know how to get the policy from the R77.30 to the R80.10 without needing downtime if at all possible. Also, I don't know how much config I need to do on the R80.10 before trying to import the policy. I have setup all interfaces and static routes and licensed the device.
Thanks to anyone who is able to help. I do have this logged with CheckPoint support but they can take a while to get back to you as it is a low priority.
