19 Oct 2010 at 00:13 #1 cheechm cheechm Associate Joined 16 Jan 2008 Posts 2,350 ..................... Last edited: 10 May 2016
19 Oct 2010 at 13:23 #2 Five_Star Five_Star Associate Joined 20 Oct 2002 Posts 1,127 Location Redcar Must be a large install with all that cable. I did the whole house (24 ports) in less than one box
19 Oct 2010 at 14:03 #3 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,508 Location Leafy Cheshire Five_Star said: Must be a large install with all that cable. I did the whole house (24 ports) in less than one box Click to expand... Far easier to run multiple runs at the same time than one run over and over again, especially when using 4 or more ports in one room.
20 Oct 2010 at 00:12 #4 cheechm cheechm Associate OP Joined 16 Jan 2008 Posts 2,350 ....... Last edited: 10 May 2016
20 Oct 2010 at 16:22 #5 Five_Star Five_Star Associate Joined 20 Oct 2002 Posts 1,127 Location Redcar Nice, I had to grub about under floors and in the loft myself.
20 Oct 2010 at 17:22 #6 dave-lew99 dave-lew99 Associate Joined 14 Apr 2008 Posts 1,230 Location Manchester Why do you have 6 BT lines? I only ask because it looks like it's your home, unless you run your business from there also?
20 Oct 2010 at 17:48 #7 DJMK4 DJMK4 Soldato Joined 1 Dec 2004 Posts 23,325 Location S.Wales dave-lew99 said: Why do you have 6 BT lines? I only ask because it looks like it's your home, unless you run your business from there also? Click to expand... Line bonding, failover, load balancing? I dont think he has specified either that all of them are going to be used for DSL. I would assume he's running a business or just wants a few bonded connections to show off at home
20 Oct 2010 at 18:32 #8 cheechm cheechm Associate OP Joined 16 Jan 2008 Posts 2,350 ....... Last edited: 10 May 2016
20 Oct 2010 at 18:59 #9 dave-lew99 dave-lew99 Associate Joined 14 Apr 2008 Posts 1,230 Location Manchester Yeah i can see that, that isn't unreasonable! At work we have 4 - two office lines, fax and alarms (those pesky alarms are expensive!)
