Chenbro ES34069
4 Jun 2008
Newbridge, scotland
Hi all,
just woundering if anyone else has this case and may be experiancing a high pitched sound that i think is comming from the PSU board in the case ? Do you think this is correct that its the psu causing the noise?
the noise even happens when there are no drives plugged in!
Cheers
If a high pitch sound is coming from the PSU board then it sounds like it could be capacitor squeal, which would mean one of the capacitors is on it's way out.
If it's still in warranty look at sending it back or if it's really new then get in contact with the store you bought it from.
you know what it is still under warranty, for some reason just did not think about that!
Cheers for the reminder, will contact them this morning
