Chepo Second Hand Building...
19 Jan 2003
Bristol, UK
What do you think the best system (including monitor) you could do for a budget of £150.
I currently have...
HDD
DVD Rom
Case
PSU
FDD
256Mb PC133 SDRam
1.2Ghz Duron CPU
It need's to be used for office and internet, also needs to have LAN connection.
Cheers,
Chris
I'd buy a secondhand CRT, 17" or maybe 19" which should cost £40 or less. Then I'd spend the rest of the budget on a fastish Sempron CPU or maybe a clearance socket 754/939 chip and more Ram. Maybe something along these lines?
CP-085-AM AMD Athlon 64 2800 Newcastle 130nm (Socket 754) - OEM (CP-085-AM)
£50.00 £50.00
MY-002-OK OcUK Value 512MB PC3200 184pin DDR Memory (MY-002-OK)
£19.95 £19.95
MB-124-AS Asus K8V-MX VIA K8M800 Micro ATX (Socket 754) Motherboard (MB-124-AS)
£34.95 £34.95
Subtotal £104.90
VAT £18.36
Total £123.26
