As above, if the keycaps are just getting worn then you can find replacement WASD only sets on the bay, but if you mean the switches are on their way out then the situation is a little more complex.
Well, having just wasd blocking the LED won't make an awful lot of difference but obviously it's user preference, but if you look around you should be able to find keys which allow backlighting to pass through the legends!
